The 2012 Coffee Forums Holiday Gift Guide!
[h=1]Cuissential SlickDrip[/h]
A quick pour-over is essential to any coffee connoisseur's weapon bag. This SlickDrip Pour Over collapses into a very portable unit. You can throw it in your purse, briefcase or backpack very easily. Pour-overs are not bad for making a good cup of coffee in a pinch. The problem with most is that they are an awkward shape. This one isn't. You can put it anywhere easily.
Buy Here: Cuissential SlickDrip - Collapsible Silicone Coffee Dripper, Filter Cone: Amazon.com: Home & Kitchen
Kitchen Trolley
This would probably seem silly to most people, but when you host as many people in your home as we do, it's nice to free up the kitchen a little bit. We put all of our coffee and tea supplies, hot water pitchers, cream, coffee machine, and cold brew carafe on something like this. I couldn't find the exact one that we have but this one is very similar. It's nice to be able to have our hot drink station just outside of the kitchen so that traffic doesn't get so clogged.
Buy Here: Amazon.com: Catskill Craftsmen Kitchen Trolley, Black Base/Natural Top: Home & Kitchen
This One Is Also Nice: Amazon.com: Home Styles 4508-95 Dolly Madison Prep and Serve Cart, Black Finish: Home & Kitchen
Breville BES900XL Espresso Maker​
I don't know about you, but we love serving our guests great espresso drinks. We've had an older model consumer Starbucks Espresso machine for a while, but it wears out quickly when we need to make a lot of drinks. It really can't keep up. And sometimes the steamer just decides not to work. If I had the money, I would like to get my wife something like this. She's a great barista and she could do wonders with a good reliable machine. It's basically a commercial machine in a consumer package.
Checkout the review of this machine: Breville BES900XL Review - YouTube
Buy Here (if you have the monies): Breville BES900XL Dual Boiler Semi Automatic Espresso Machine: Amazon.com: Home & Kitchen
Porlex Mini Stainless Steel Coffee Grinder
Porlex is a Japanese company that specializes in food grinders. This grinder is very well made with a well thought out design. This is one of the most compact, useful grinders on the market. The silicon allows you to have a firm grip on the cylinder while grinding. The handle comes off and you are able to store it alongside of your grinder when you are not using it. The grinders inner spring helps keep the grind consistent even when grinder for coarse brewing. The stainless steel body makes the grinder indestructible and static free. The ceramic, conical burrs are easy to clean, will last long, and will remain rust-free.
  • Ceramic conical burrs with wide range can grind from powder to french press
  • 20 gram capacity
  • 47 mm diameter and stands 130 mm tall
  • Made in Osaka, Japan
  • Stainless steel, static free body
Price: $75.00 - Amazon Link - Porlex Mini Stainless Steel Coffee Grinder: Amazon.com: Kitchen & Dining
Bonavita 1-Liter Variable Temperature Digital Electric Gooseneck Kettle
Bonavita 1-Liter Variable Temperature Digital Electric Kettle
The Bonavita Variable Temperature Electric Kettle is a 1.0 liter capacity stainless steel kettle with many unique features. Users can select from six present temperatures or can set their own temperature from 140 degrees F (60 degrees C) and up. The 1000 watt heater boils water quickly and will hold the set temperature for up to one hour. The kettle has a unique spout that allows for a very controlled water pour that is needed for manual brewing of coffee and great for tea steeping as well. Our kettles have been used by World and US Champion Baristas based on its build quality and pour control.
Features
  • Temperature set/hold for 60 minutes
  • Accurate to within 1-2 degrees F (or 1 degree C) to set temperature
  • Count up timer for timed coffee brewing or tea steeping
  • Actual water temperature displays on LED
  • 1.0 liter capacity
  • Powerful 1000 watt heating element (AC 120V 60Hz)
  • Commercial UL certified (USA); UL rated in Canada
Accuracy
Six preset temperatures or user-selected in one degree increments from 140 degrees F (60 degrees C). Holds set temperature for one hour. LED display shows water temperature. Display accurate to +2 degrees F.
Versatility
Unique spout for pour control. Use for manual coffee brewing, tea, or your favorite hot beverage.
1-Year Warranty
The Bonavita BV382510V Variable Temperature Electric Kettle is fully UL Certified for safety compliance and features a 1-year manufacturer's warranty.
Price: $89.99 - Amazon Link - Bonavita 1-Liter Variable Temperature Digital Electric Gooseneck Kettle: Amazon.com: Kitchen & Dining
Chemex Drip Coffee Carafe - 6 Cup
Coffee purists appreciate the classic styling of this carafe with wood collar and tie. The Chemex filter drip method eliminates bitterness, and the slow brewing allows full flavor from the best coffee beans. Unlike flat bottom filters, the conical shape concentrates grounds at the bottom of the filter, ensuring a clear flavorful coffee without fail.
  • The Chemex coffee maker has been brewing clear, pure, flavorful coffee without bitterness or sediment for over forty years and remains one of the purest methods of brewing.
  • Coffee can be made at the preferred strength.
  • Simple to use: Place grounds in the cone-shaped filter at the top and pour hot water over them.
  • The polished wood collar and leather tie serves as an insulated handle.
  • Elegant, eco-friendly and simple!
Price: $36.95 - Amazon Link -
Chemex Drip Coffee Carafe - 6 Cup: Amazon.com: Kitchen & Dining
The Blue Bottle Craft of Coffee: Growing, Roasting, and Drinking, with Recipes
One of the country's most celebrated roasters explains how to choose, brew, and enjoy the new breed of artisan coffees at home, along with 40 inventive recipes that incorporate coffee or taste good with a cup.
Coffee is experiencing a renaissance and Blue Bottle Coffee Company has quickly become one of America’s most celebrated roasters. Famous for its complex and flavorful coffees, Blue Bottle delights its devoted patrons with exquisite pour-overs, delicious espressi, and specialized brewing methods.
Yet as coffee production becomes more sophisticated with specialized extraction techniques and Japanese coffee gadgets, the new artisan coffees can seem out of reach. The Blue Bottle Craft of Coffee explains this newworld from farm to cup, exploring the bounty of beans available and the intricate steps that go into sourcing raw coffee from around the globe. Blue Bottle founder James Freeman coaches you through brewing the perfect cup ofcoffee, using methods as diverse as French press, nel drip, siphon, and more to produce the best flavor.
For coffee lovers who want to roll up their sleeves and go deeper, Freeman explains step by step how to roast beans at home using standard kitchen tools—just like he did when starting out. The Blue Bottle Craft of Coffee also introduces a home technique for cupping, the industry method of tasting coffees for quality control, so you can hone your taste and share your meticulously roasted coffee with friends.
Rounding out the book are more than thirty inventive recipes from Blue Bottle pastry chef and former Miette bakery owner Caitlin Freeman thatincorporate coffee or just taste particularly good with coffee, such as Saffron Vanilla Snickerdoodles, Stout Coffee Cake with Pecan-Caraway Streusel, Affogato with Smoky Almond Ice Cream, Coffee Panna Cotta, and more.
With more than one hundred stunning photographs showing coffee’s journey from just-harvested cherry to perfect drink, this distinctive and deep guide to the new breed of amazing coffees from one of the top artisan coffee makers will change the way you think about—and drink—coffee.
Hardcover: 240 pages
Price: $13.98 - Amazon Link - The Blue Bottle Craft of Coffee: Growing, Roasting, and Drinking, with Recipes: James Freeman, Caitlin Freeman, Tara Duggan: 9781607741183: Amazon.com: Books
Hario VKB-120HSV V60 Coffee Drip Kettle Buono
Made in Japan, ideal for making the perfect cup of drip coffee at home.
Product Description
Shaped like a beehive, this stylish stainless steel kettle is perfect for coffee dripping. A long, slender spout allows for a slim and smooth flow when pouring. It features a black easy-grip handle and a lid with three mini ventilation holes. "best new product" winner at world tea expo 2009
Product Details
  • Amazon Sales Rank: #873 in Kitchen & Housewares
  • Color: Black
  • Brand: Hario
  • Model: VKB-120HSV
  • Dimensions: .94 pounds
Features
  • Capacity: 27 oz. for 3-4 cups
  • Dimension: 10¾"Wx3"Dx5¾"H
  • Can used directly on an IH range, electric stove and gas stove
  • Can be used with Hario V60 Coffee Drippers
  • Staineless Steel
Price: $52.50 - Amazon Link -
Amazon.com: Hario VKB-120HSV V60 Coffee Drip Kettle Buono: Kitchen & Dining
Hey,
Why don't you try a coffee mug, the best gift for coffee lovers. So many designs and varieties are available in mugs and you can also make your own personalized mug by creating or selecting your own design on mug. This gift seems to be the best one for coffee lovers.
