- Thread starter
- #16
Re: MikeLev also mention messy brewgroup
I guess it depends on what you mean as messy. When I pull it out I sometimes find some grinds at the bottom of the plate, but not many. The brew group it self is pretty "clean" until I run some water through it and then the grinds come out easily. I would say it is way less messy than what I went through cleaning up after my semi-automatic (don't even ask about that one, it was an old one that didn't make espresso well at all).
Deej said:Mikelev sez: "And the Brew Group gets a lot messier than the Vienna's did with coffee smeared all up and down the shaft (even beyond the rubber seal)..."
JerseyGuy..... Is the brewgroup typically messy when you pull it out? I wonder if there's a difference in procedure between the way you and MikeLev use your machines?
