Alun_evans
- Feb 4, 2004
- 1,065
- 1
Hey Ron, sorry I had to read back over what I had written because not only had I confused you, but also myself!! :grin: Actually what I was refering to was a situation where a cafe has an espresso blend and also runs a grinder for SOS. The espresso blend, being a blend of different beans, normally requires very little up/down adjustment to the grind during the day. HOWEVER SOS will require much more adjustment as a shot using Java Estate will grind and pull differently from a higher altitude Irian bean- even with the beans having a similar roast. The actually difference in grind between the espresso blend and SOS may not be huge...but any difference in espresso is a big difference as we all know! I guess my point was I recommend having two grinders...but then if you have decafe you may end up having 3 grinders set up!!! MAzzer Luigi does not sponsor btw- :wink:
