Thanks. I did watch James Hoffman's video again. When I did use his method, I found some foam, but no crust at the top after 4 mins. But when I used that method, I was also using very coarse grind. I will try it again using medium grind.
Also, not plunging makes sense to me. Only issue is that my pot is stainless steel, not glass, so I have to estimate how far to push the plunger. But I suppose it really isn't critical, so long as the filter is below the spout, and I pour slowly.
I'm thinking of buying some Lifeboost organic beans. They're offering a 50% off coupon for first-time buyers, but after that, I really don't have the cash to spend $100 on 36oz coffee. Of course, if I add up how much i would spend at DD (forget about SB) if I purchase my coffee, the cost isn't so high, so long as I can use the entire 36oz before the beans lose significant flavor.
If I do go for some expensive beans, I will also invest in a good storage jar/can and a better grinder.
First, the foam you see after 4 minutes is just the CO2 escaping from the beans. You will want to scoop all of the foam off as well any coffee grinds floating near the top. The foam is bitter and will give you bitter coffee in your cup. It isn't like the crema you get from espresso which is good. French press foam is bad. Then put the plunger back and push it down until you see a little coffee come through the screen. Then just leave it there for the rest of the brew. I let my coffee sit after scooping the foam and grinds for another 7 minutes. I no longer get bitter coffee. Before I saw that video my coffee was always bitter from my french press. I now use it to make my wife Iced Decaf Mocha Lattes similar to what she used to get from Starbucks but with french press coffee instead of espresso. I just drink my french press coffee with some manually frothed skim milk. I heat the milk to about 140F which brings out the natural sugars in the milk and do about 2/3 coffee to 1/3 milk and foam. Delicious.
As for your grinder, it may not be your grinder that is the issue. It could be your beans. Fresh beans are key. I buy my beans from a local roaster and they tell me that when I pick them up it is usually around 3 days after the roast date. I try to use the entire pound within a month. It's critical to know when your beans were roasted. But even that may not give you bitter coffee. Since you've been plunging, I'm thinking that it could be a combination of plunging and not scooping all the foam and floating coffee grinds after 4 minutes. Keep at it. Once you get a handle on the process you'll look forward to making your coffee every morning.
