Sharing Suggested Labels for Super Jolly Grinder To Help Staff & Screw As Alternative Collar Handle
jimtmcdaniels
Colo Spgs CO USA
Hi, we painstakingly made labels for our super jolly, thought we'd share for anyone wanting to print & do the same for their staff:
Espresso-Coffee-Grinder Doser-
Mazzer, Model “Super Jolly”
Serial #, 110vac 5 amps
31 lbs, 2.7 lbs Bean Hopper Cap.
64mm Flat Burrs, 1,750 RPM.
4g. Retention Grinds.
Manual: (make QR code using Adobe)
https://lamarzoccousa.com/wp-content/uploads/2023/09/Mazzer-All-E-Grinders-User-Manual-1.pdf https://www.manualslib.com/products/Mazzer-Coffee-Grinder-Super-Jolly-3692831.html
PortaFilter Holder
(To Adj. Fork Sideways:
Loosen Lower Screws)
CW=Fast & COARSER.
C-CW=Slow & FINER.
W/Motor On-
Turn Collar To Adj.
(Adj. Dose Size Lastly.)
ON
Turn On ≤ 35 Sec.
(To Avoid Overheating)
Grinds Approx. 1.6g. Per. Sec.
W/4g. Residual Chute Grinds.
Fill Doser Star Wheel.
Dose Size Adj.-
Turn Star Center Knob:
C-CW=Increase.
CW=Reduce
Dose Counter
Dosing Chamber
Max. Cap. 300g.
Dose Trigger
Unplug B4
Cleaning/Servicing
Beans-Drop
Stop-Gate
Occasionally Clean Hopper:
Unscrew Fastener Screw & Remove.
Grinding System Cleaning:
See Manual p11.
To Remove Collar/
Access Hazardous
Grind Chamber: Unplug
Unit, Then Turn Collar CW
Hopper Removal
Safety Screw
Also, if you're missing the pricey grind collar adj. handle or want more, just a long screw size 10 thick x 32 thread count will screw right into any of the multiple collar tapped holes.
Take care
