Roasting Light
Law104
Good Day,
To date I have been roasting to the start of 2nd crack. I have noticed that if I try and shorten my DTR I get underdeveloped coffee, noticeable by taste. CGA's present.
My question is, how do I approach a light roast while maintaining a fully developed roast.
Hotter or colder charge temp relative to my standard roast?
Longer or shorter period in the first and or second phase? etc
I am concerned that if I drop at FC or soon there after I will be well underdeveloped.
Many thanks..........
Good Day,
Can you post an image of a profile that you thought was underdeveloped? That might help us understand what's going wrong.
Start of second crack is full medium. As above, post curve but it sounds like you are just blasting through the first two phases
Good Day,
My question is, how do I approach a light roast compared to a typical roast?, see attached. My concern, should I shorten the DTR the roast could be underdeveloped. On a typical roast, should my drop temp be any lower than 221 C, it will be underdeveloped. I can roast with a shorter DTR and achieve a 221 (plus) drop temp. This will shorten my DTR. Will this roast then be underdeveloped.
Please bear in mind I am self taught, so some of my questions may be unclear. Feel free to query me as above .
Regards............
Your charge temperature should be fine... you are hit mallard about 5 minutes which is about right. I would suggest slowing down your roast between mallard and first crack - 3:20 is pretty quick through that stage. I tend to get baked/underdeveloped notes when I roast too fast through this stage. Lastly, your time from the first crack to drop will be shortened since you will be roasting lighter/dropping earlier. I typically try and hit milestones of 4:30-5min to mallard, about equal time from mallard to the first crack, then 90-2min in development (from the first crack to final temp). I.E. 5min to 150-155C, 930-10min to 195C and drop around 11:30-12min at 210C. Of coarse everything will vary a bit depending on load size/ roaster / goals.
One other possibility with Rawanda. How old is the coffee ?
Rawanda did have some issues with the "potato disease" a few years ago. I think it was o.k. last crop but I don't know about the 17/18 crop
Musicphan thank you,
I have noticed that my 2nd phase is short (End of dry to FC), any suggestions on when and approx by how much to reduce pressure without loosing the the roast. My thoughts would be to start reducing pressure around max ROR and using less pressure during the middle phase.
Regards.........
It's really roaster specific ... but I would start cutting back energy earlier - maybe around 4 min or so. Your coffee will have enough energy to keep it rolling to your peak ROR. It's really trial and error... aka the art of the roast :)
Musicphan, thank you.
Here is a lightish roast I did yesterday. Nothing at all underdeveloped about it.
Looking good... you may want to stretch out it a bit more in the development period.. but it's obviously too your taste buds. When I'm first getting a coffee I try and dial it in via this method... https://www.youtube.com/watch?v=sct2FWVkmDw . Neal wrote Typica which is another roaster software... super bright guy. This process, however, is not very good if your trier is small...I'm not sure what your roasting on.
Almico thank you,
May I ask what roaster you use?
The graph looks great, I am sure the coffee taste good.
Thank you,
I am roasting on a Diedrich IR 5.
Almico thank you,
I have a significantly modified, fairly generic 5kg Turkish roaster. It's a 2017 model that I found used and cheap! I'm negotiating a new roasting location now and thinking about getting an K&M UG15.
I find most high density coffees do well in this roast development range and drop temp. If I go longer and hotter, let's say to 400* it loses acidity and picks up astringency. Beyond that (415*) the acidity is mostly gone, but so is the dryness. The trick is to get it hotter faster and build the pressure in the bean early. This pressure, like a pressure cooker, helps force the heat transfer to the inside the bean quicker.
