Have you tried making your own caps? Wash out the k-cup just as you would for a my-kap and let it dry. Fill it and cover it with heavy-duty aluminum foil and make sure you crimp the edges with your finger. I had some issues with the foil splitting at the top and causing leaks (as is also described in the my-kap FAQs), and this can be fixed by using self-adhesive paper dots at least 1 inch in diameter. I haven't yet exceeded the life of a reused k-cup!
