Axel
- Jul 15, 2015
- 32
- 0
- Thread starter
- #16
Thank you ellatasThe high airflows on a fluid bed roaster are generally thought to have less complexity, but not necessarily less body. For a drum roaster, the airflows can be much lower since the mixing of the coffee is done mechanically by the rotating drum as opposed to the air. Also, on most commercially made drum roasters, air is passed through the drum to not only roast the coffee, but to remove chaff. If chaff remains in the drum, it will burn and impart a smokey flavour to the coffee.
The heat transfer to each coffee bean within a drum is approximately 80% convection from the air, ~10% conduction from bean to bean, ~5% conduction from drum to bean, and less than 5% radiant from drum to bean. If there is no airflow at all, the other pathways dominate more and the drum needs to be a lot hotter to roast in the same time. The flavour profile will be different.
Specific flavour profiles (such as floral and high notes) depend more on the coffee type and the time/temperature profile it is subjected while roasting. All roasters will produce their own unique flavour profile and it can be difficult to replicate from one equipment type to another. In building your drum roaster, accept that it won't roast the same way as other roasters, but that doesn't mean it won't be capable of producing great roasted coffee.
that is an explanation even I can understand. seems you have great in depth knowledge of roasting to be able to convey the idea so quickly and simply.
It sure reinforces my understanding of the roasting process as having infinite combinations of variables...
Convection
How should I figure out the air flow through the drum?
I realize that having fine control of airflow is an important feature but where should I start?
on a 24"x30" double wall drum(two 14gauge layers) rotating at about 50rpm, how much horsepower should the exhaust have available?
And more precisely.. how may CFM's(cubic feet per minute) should be a comfortable max ability?
would it be about the same with a single layer at about 11gauge?
I'm guessing that the inherent draw of hot exhaust air out the chimney/stack will do some of the work..?
Radiant
What is an optimal amount of space between the two 14gauge layers?
I've been told 1/2" can be found on some roasters, would less space(say1/4", closer to a single wall) allow for more responsive control of temperature?
I guess the question should be: if I could choose either a double wall or single wall drum, which one is better(has more relevant benefits)?
How much contact should the two layers have? just at the ends?
