I just bought a used Diedrich IR2.5 (2012) and am going to place it in my garage / shop for home roasting. For venting, Diedrich recommends manufacturers like Selkirk Sure-Temp, etc. My question is what is the most efficient way to vent. Ideally, one would use positive pressure double walled pipe which is fine for a commercial operation. Mine will be used for an hour or two every 3-4 weeks. That aside, to go vertical and through the roof, a series of 30 deg elbows is required to achieve 90 dgrees, some straight pipe, then a roof kit. This is possibly the best way but is it? I have seen a short horizontal pipe through the wall, then a short 90 degree elbow. Ths would not elevate the stack to roof or chimney height, but is that necessary unless you are in a production environment? Aside from my city's residential permitting process and building codes, for the best roaster operation and efficient airflow, does a short horizontal pipe get it done? Is a 90 degree elbow, then go vertical 12 ft more efficient? I don't expect to find HVAC engineers amongst the roasting community, but wanted to avoid having to hire an HVAC consultant. Thanks!
