unit_number_43
- May 8, 2006
- 23
- 0
From experience I can say that a morning coffee mixed with a morning cigarette means a mad dash to the restrooms. It deffinetly has a flushing effect. But I wouldn't call what it does to me "regular".
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
unit_number_43 said:It should probably also be noted that if you let the oils from the beans sit in your coffee machine or coffee pot for a couple of days it will give you a pretty bad case of the runs. I'm not sure of the scientific reason behind it, but it does. Just remember to clean your machine after every use.
demetri said:It's the fruit around the bean that is a laxative. When extracting the beans from the fruit if not done correctly the laxative will remain. Cheap coffee usually means a cheap method of processing the beans and extracting them from the fruit. Expensive coffee will not have the laxative or the effect.
