Which Coffee Machine Should I Purchase?
eileen0998
Hong Kong
I just starting to dive into the world of pour-over brewing. Any recommendation?
I'm looking for something that strikes a balance between simplicity and delivering great taste. Any suggestions for pour-over coffee makers, grinders, and any essential accessories would be fantastic!
Maakbow
New Zealand
Any recommendation? I'm looking for something that strikes a balance between simplicity and delivering great taste.
I'm not a pour over 'expert' as I'm more a spro bro, but i can say without hesitation , If you are starting out, you will get your best results spending your money on a quality grinder and make your pour overs manually. Good mechanical pour over machines that are on par with a well made manual pour over are relatively pricey.
I don't know what your budget even is but the best hand grinder you can find (read/watch as many reviews as you can) may be good enough. Like 1zpresso JP6, ZP6 or maybe even K-Ultra.
As soon as you jump to an electric grinder your budget will need to be multiplied. Maybe a Lagom mini or fellow opus might be a good starting point but there are so many options. These are filter focused grinders so should you later want to make espresso they may not be you best choice
Coldbrew_withoutice
Austin
Welcome to the coffee world! I would say if you just started (like me) a machine that does it all for you might be easier (at least it is for me)
I also want a brand that will take care of the beans for me. I want to learn more about coffee beans but really don't know where to start.
Any good brands rec??? I am also opened to ideas.
Coldbrew_withoutice
Austin
I was looking at Fellow the other day......their design is cool! But I am not sure if I know how to use it...
Would love a machine that it probably does all the work for me (but not a K-cup lol
Apeace
29
USA
I am new to coffee too, so I am searching for various options now. Personally, I am reading reviews and comparing different models, it helps to make a decision. I fond some interesting options at famous tate. Consider factors like the type of coffee you enjoy (espresso, drip, etc.), the size of the machine, and any additional features you might want, such as a built-in grinder or milk frother.
shadow745
Well-known member
Aug 15, 2005
1,831
77
Central North Carolina
Still don't see the hype on the Lagon Mini... pay that much and limited to 2-3 grind sessions daily per their recommendation. Personally wouldn't limit myself to just three ristretto extractions daily if the turd was free.
I personally recommend the Chemex, it is simple and elegant looking in its simplicity.
More important in your brewing is your water and temps.
I recommend water that has not quite reached the boiling point, pull just before the full boil roll starts.
method of pouring the water over the grind is also important, not too fast, do it slowly and in circular motions to seep all the grind. pause a little after the first few seconds and give a little bit of blooming time for flavors to pop.
JeffD
Active member
Jan 27, 2022
252
39
Upstate New York
I think the real first step is to learn. Everyone can recommend equipment, and most people recommend what they use, what they like, etc. Lots of good videos out there. Lots of great books recently published. The more you understand, the more you can judge what you want, and how to strike that balance for you.
froze
51
6
Odd, I can't find my previous post.
Here I do again. I had a Hario V60 pour over but to me, the coffee was on the weak side for my taste. I decided to try the Hario V60 Switch, and all the reviews I read liked this one the best. The Switch is a combination immersion maker and a pour-over. This maker makes the coffee a lot stronger than a standard pour-over, and stronger than a French Press or AeroPress as well.
The only bad reviews on the Switch are mostly user error. The biggest complaint is the switch on it is made of plastic, and some people have pressed it too hard and broken it. It's just plastic and it moves up and down very easily, there is no need to force it, just barely touching it moves it. The other complaint is there is a ball bearing inside the unit that shuts off the flow, that ball bearing is loose, so if you tilt the maker onto its side or upside down that bearing will come out and fall wherever it goes, and maybe someplace you can't find it ever again!
Just watch YouTube videos on how to use it, if you have any other questions about it just come back here and ask, hopefully, I'll see it and can help you, but I'm sure others can help you just as well as me.
