BEZZERA MAGICA SINGLE FILTER LEAKING FROM BREW HEAD
assaf.aman
Hi everyone,
I have the machine for approx. one year.
I enjoy it very much.
Lately though I have this issue.
Every now and then, and only when I use the single filter (double no issues at all) I experience a small coffee leakage from the left side of the brew head.
I tried to tighten the filter, tried to clean the head seal (although as I said, it happens only with single filter), nothing helps.
Needless to say, Im using all the original accessories.
Any ideas?
Cheers
shadow745
Well-known member
Top Poster Of Month
Aug 15, 2005
1,831
78
Central North Carolina
Could be a few things relating to single basket use... one is the dose might be a bit much and not letting things seal up as needed OR it could be the basket itself. Not all baskets will seat the same way as in the rim design can vary.
assaf.aman
with regards to the basket, as I said it's the original basket so I must suppose it should seat properly.
as for the dose, that's an excellent tip. I will try it ASAP and update
MarcBeck
34
Hawaii
Have you replaced the group head gasket? I'd start with that. The double basket might just sit against the gasket a little different than the single and that's why the double doesn't leak. Also, I hate to assume....but have you looked closely at the single basket to see that there isn't a dent in the rim?
assaf.aman
Hi
I must assume its not a gasket issue as the machine is one year old...how ever I have the spare supplied with the machine so I can consider doing that.
As for dent, no dent.
as per the advise in a previous comment, I reduced the amount of coffee and it seems to solve the issue. I need to gather statistics.
I must admit that I failed to notice the obvious and that is not to exceed the marked line in the basket...
assaf.aman
one year old gasket ? How often do you use your machine ? If gasket is hardened, you gotta replace it
I use it almost on a daily basis. Further more I rarely turn it off, which could definitely harden the gasket.
For now I stick with the coffee overflow option. I will check for a few days and update
shadow745
Well-known member
Top Poster Of Month
Aug 15, 2005
1,831
78
Thing is the stock rubber type gaskets just don't hold up well over time as it does see a ton of wear in the form of heat, friction, etc. Personally don't buy into leaving a machine on 24/7 or especially a claim like that of Rocket to leave the portafilter locked into the group at all times to minimize gasket wear. I strongly recommend replacing the dinky stock gaskets with a quality silicone like those made by Cafelat. Those things don't wear/degrade/harden like OEM (rubber), seal much better/smoother and cost is nearly the same.
