tarik2.0
:info: If you are pregnant, you should completely avoid using caffeine.
If you have an issue with decreased adrenal function or adrenal fatigue, caffeine can actually create more stress on your adrenal glands. In this day and age, many people are constantly stressed and fatigued, and rely on caffeine for sustained energy to get through the day. If this is the case, it is a tell-tale sign that your body is not functioning properly and you need to address the underlying problems.
Adrenal fatigue can wreak havoc on your health. The adrenal glands affect every organ and system in the body - from metabolism of carbohydrate, protein, and fat, to fluid and electrolyte balance, cardiovascular system, immune system, hormonal system, and even your sex drive. Therefore, if you have adrenal fatigue, pumping your system with caffeine is merely going to aggravate your problem in the long run.
Coffee has a diuretic effect. If you have problems with electrolyte balance, you may want to avoid it too.
If you drink coffee and have problems falling asleep or tend to wake up in the night, you may be caffeine sensitive. Caffeine levels vary depending on the type of roast, grind, and brewing method. Darker roasts contain less caffeine than lighter roasts. The finer the grind, the higher the caffeine in the coffee. Drip coffee has more caffeine than espresso because the brew time is much longer. If you experience sleep issues from the caffeine, you may want to vary your type of roast, grind, or brewing method or cut down on the amount you drink every day and make sure you only have coffee early in the morning.
If you experience stomach cramping, heart palpitations, or other symptomsafter drinking coffee, you may actually have a food intolerance. There is also the possibility of mold (coffee is a dried food and may contain mold) or other contaminants in the coffee that trigger a physical reaction.
