anonemis
I own a Keurig 2.0 single serve machine. I use my own ground coffee but the taste is "watered down". The coffee doesnt appear to be as hot as other machines. What is your favorite single serve? I heard alot about ninja machines.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I use a bonavita full immersion dripper.
While it brews a single cup of coffee in a similar way to a french press, the cleanup is very easy.
I have been using it for about 7 years now.
It is extremely simple and fairly cheap ($27 amazon).
https://www.amazon.com/Bonavita-Wide-Porcelain-Immersion-Dripper/dp/B00MFJX7P4/
I grind according to my filter.Do you grind your coffee beans as you would for a drip grind coffee maker, or do you grind it different for this brewing method? (coarser or finer)
