Saeco Odea Go - cold water leaking at bottom of unit
cjduke
Hello All,
Thank you for viewing my post. I have a Saeco Odea Go machine that leaks cold water under the machine just outside of the location for the flow meter valve. It starts as soon as the pump starts to work and I suspect the flow meter is the culprit. I took the machine apart and did not notice any corosive contacts on the electrical connector but I still susptect this part as defective.
The tubing looked intact.
Anyone else have any ideas or similar problems.
Thanks again.
