Axel
I've seen both belt and chain reductions on roasters but no worm drives or gear set ups.
Is that because manufacturers want to reduce the amount of heat transfer from the drum shaft to the motor?
I'm thinking of doing a 40:1 worm drive reduction from the 1,725RPM 1hp motor to a 1:1 chain and sprocket connected to the drum.
this way I get a rotation speed of about 43RPM at the drum.
Any less expensive options out there?
