Questions on Convection Oven Roasting
davidsbiscotti
Does anyone here use a convection oven for roasting coffee beans?
It provides good circulation for even roasting and of course a good exhaust system for venting the smoke.
I use a Duke "E" Series convection oven (two actually) for baking.
I use perforated baking pans with raised lips and have cooling racks to put them on. I can roll the racks into a cooling room, about 50 degrees farenheit. Is this an efficient method of cooling for coffee beans after roasting?
Is chaff a problem in convection ovens? Does the chaff blow around and eventually clog the fans?
How does a roaster deal with chaff anyway?
I've read through some postings on this topic that were from upper level roasters that went way over my head.
I'm hoping for some advice on a level that an amateur roaster could relate to.
convection oven
If I wanted to write to myself, I'd go home and write in my journal.
These are genuine roasting questions from a new coffee enthusiast.
Come on guys, humor me.
Maybe you should start journaling, or maybe you should put "homeroasting" into your search engine. There are many sites out there with forums, instructions, etc. It is a big hobby now, witness the amount of 1 and 5 pound bags on ebay. Good luck!
Thanks Ed,
Yes, there are various forms of information out there on this topic,
Just thought I'd give this forum a shot at it in the meantime.
I've been looking elsewhere as well.
I have a rotisserie/convection oven which came with a stainless steel wire drum and I have been toying with the idea of using it to roast beans when I am trying out new blends. I would be able to roast smaller samples than what I currently roast in my 2.5kg roaster at work. I would think it would work better if the beans were being stirred also.
Sorry, David- been asleep at the switch, here.. There are tons of places to read lots about convection oven roasting using what is termed "sc/to" for the home roaster. You can try coffeegeek.com or home-barista.com, but here are some direct links to specific pages on sc/to's:
http://biobug.org/coffee/turbo-crazy/
http://peter4jc.googlepages.com/
http://turbocrazy.atspace.com/index_files/project.htm
Read all the blurbs on the pro's/con's for each modification, as it requires a bit of "diy" skills, but nothing too difficult-- many, many, many folks have done this, so it really is pretty easy. Short of the Behmor, or perhaps spending $4000 on a commercial sample roaster, you probably can't do much better in terms of getting a good roast (total cost is usually < $100, unless you purchase a Variac to control your household voltage).
Hope this helps??
Ray
This is a lot to take in, but I will check the links you posted.
As sfrank57 pointed out, the stirring factor is something I hadn't considered. My convection oven doesn't have the capability (no rotating drum, just stationary shelving).
So far, because of the small quantities I would need to roast, I'm thinking the fresh roast 8 plus is my best option, although I was hoping to make use of my existing equipment.
Roasting coffee beans isn't the easy task I thought it might be, but I will persevere, albeit with limited funds.
Thanks again guys!
P.S. - Thanks EPD for the nearby green bean connections.
Fresh Roast Plus 8
I really like the Fresh Roast plus 8 because it is simple to use and real fun to watch, the only draw back is the amount it roasts at a time, so I have 2 and usually roast a pound a week with them. Turn them on and watch them cook!
Standard Electric or Gas Convection Oven... WORKS GREAT!!!
First off, some avid home coffee roasters are bit too staid and stiff for their own good in many forums online, to tell you how to do this. Some are just too picky and touchy or proud to even try this method or at least one that doesn't cost them money (it's the "I've Got To Keep Up With the Jones syndrome I guess). Yet it's so simple, even your grandmother likely home roasted coffee in her standard oven. Sometimes you'll find a few members in these forums that want to keep it expensive and complicated so they feel better about their skills and knowledge. Answering your rather simple request doesn't get them points or make them look "Cool" in these sometimes rather highfalutin forum memberships. The other side of these self professed coffee roasting connoisseurs are those that pride themselves on being "Coffee Red Necks". They'll just tell you "Why he.., I just go out to my garage/shop, get my blow torch fired up, throw some beans in my dog's stainless water bowl and roll 'em around till they turn brown to my liking's"! lol.... but mainly most members just don't have the time or desire or maybe aren't adventurous enough to try a slew of different methods and then explain them to others online. Some? ....er well... the wife/husband just flat out won't let them do their roasting in her/his/their kitchen oven! :D
So back to roasting coffee in your "standard convection oven" right now in your kitchen (just let me say I've owned some expensive fancy roasters, barbecue drum setups, etc that don't do any better of a job roasting coffee than my convection oven has done after experiencing a few screw ups. If your a stickler for precision and flaunting your coffee roasting skills, Top Brand Names, etc, then this isn't the method for you to try). Don't be afraid to make mistakes though, smell up your house/kitchen with smoke, burn your fingers a little, and maybe eat pizza afterwards with a hint of Coffee Bean flavor and you'll be just fine (actually Coffee and Pizza flavors go quite well together). But just to let you know, I do prefer to roast coffee in my fancy roasting machines/barbecue for a variety of reasons, yet I still occasionally (in winter when I don't want to go out into my frozen shop, heat it up, etc) will throw some beans into my standard "Jenn Air Range" convection oven to roast. Like you say... in reality done properly, their extremely consistent temperatures and air circulation actually make it so you don't need to really stir them much (if at all) and NO.... there is no chaff flying around in your oven either.
Just remember there are 3 kinds of heat transfer/generation used to roast coffee beans. Conduction is transfer of heat directly by contact with a hot surface and this means of heat transfer is what roasts beans in a pan on a stove top. It's the one where you really have to be concerned with keeping beans moving. Second; is Convection Heat and it's the transfer of heated air in circulation (heat rises, fans, etc). This is the primary method of heat transfer in most common home coffee roasters, heat guns, popcorn poppers, etc. Last but certainly not least... is Radiant Heat (non-heat transfer generation method). Which is where the solid molecules of water/oils within the beans are excited by waves of energy to produce their own heat from within. A pure example would be roasting coffee beans in your Microwave Oven. There are even roasters (Black & Decker makes one) that use this method to roast beans. I've tried them and although they do work great for very small batches you really have no control for consistent bean roasts/batches.
But the reality is that all methods of roasting coffee, utilize Radiant Heat to a greater or lesser degree. This is what's actually roasting your coffee beans if they're done properly. Conduction, convection are just indirect forms of heat transfer to get the beans actually roasting themselves from the inside out w/ their oils and water. Rather than depending on the beans to solely create their own radiant heat in a microwave . The whole object is to transfer as much heat without burning/scorching the outside of the beans and your Standard Home Range Convection Oven, can most likely provide a near perfect means to do it, without buying any additional roasters, drums, popcorn poppers, heat guns, etc!
Bean choice is important for your first time, depending on your present coffee tastes. If you are one that loves Bold and rich coffee flavors, then you most likely won't be happy with the predominantly more subtle fruit, flowery flavors of Dry Processed coffees out of Ethiopia for instance. Stick with more traditional American tastes in Central and South American coffee beans instead then. Read your cupping's and reviews concerning the beans you buy to roast.... first. Because they can make your first try good or bad and you may never want to try roasting coffee again, if bad. If you don't really know what you like and aren't just the typical Costco Kirkland Bold coffee lover, I'd be a little more adventurous and try a North African Dry Processed Coffee to roast then. Near anything from Ethiopia, Kenya, etc should work well for you.Some people say you should use a solid thicker perforated cookie sheet in your home oven and those are fine, but provide more conductive heat, that could scorch or burn spots on beans. So just for trying it out and/or roasting occasionally, like I do in my convection oven, I use aluminum foil (or pizza screen) and actually... in some ways they're better.
The reasons are that you don't have to ruin the wife's cookie sheets or baking pans drilling/punching holes in 'em for one. But mostly because you're using less Conductive Heat Transfer to beans instead. Naturally most well designed Convection Ovens will be really even in heat distribution throughout your entire oven. But I've found a level or two up from center works best. Form your make shift aluminum foil pan in your cookie/baking pan with turned up and doubled edges. Pull it back out of it and punch a slew of holes for convective air flow with it sitting on your oven rack or if you do have a fine wire mesh pizza screen they work great instead of a foil pan too. The whole idea is that the less contact with thick conductive heat source you have the more even the roast. Just think if you could roast coffee beans suspended in mid air currents, that would be ideal. So you pre heat your oven for your first attempt, to between 425*F and 475*F. Have a large wire strainer and large bowl ready for cooling and getting the chaff off the beans. Mittens naturally to handle everything after roasting and one of your oven racks to set the formed foil baking pan or pizza screen on.
Now I will usually make ready enough beans to cover the pan or screen's surface with beans, just touching each other prior to roasting. Depending on the beans, set your timer for 10 min (if using 475*F temp, 15min for 450*F and 20min for 400-425*F). Just remember these are only initial guidelines. So for a Harrar Longberry for instance (that's better at a lighter roast), you may or may not use these times. At 475*F I will generally get 1st Crack starting at around 4-5min in. Hopefully your oven has a glass front so you can watch while listening for signs of cracking and when it stops, etc. You will see some slight movement of the beans as the chaff pops off on cracking. But I've never had chaff flying around in my convection oven... ever.
Next you'll start to see some smoke out the vent at around 7 to 8 min at this higher temp. Now just be listening for cracking and whether it slows or stops and this should get you a nice city roast somewhere within the final 2 min. Which is preferred for these sweeter, fruity high grown African dry processed beans. If you like coffee closer to Full City, then you should see that roast level happen at around 11 to 12 min into roasting (at 475*F). Look for when 2nd crack begins or slightly into 2nd crack. With experience you'll find out just how your particular oven works. So these are just initial guidelines remember. But also remember that for the time they're roasting you can't go off and read a book, etc either. When you determine that they're done, quickly open the oven, pull the perforated foil pan (or pizza screen) and fold the foil up to make it easier to pour into the strainer over the bowl. Have a screen or piece of foil ready to cover the strainer (crimp edges), so you can take it outside and shake the beans till cool (do this fast as you can). Now use your hand to mix the beans around in the strainer w/ bowl underneath to further clean chaff from them. Hopefully you don't have too much chaff outside the range/oven, but it's easy to clean up.
That's it.... you'll find that your freshly roasted coffee beans should look fairly consistent in roast over the whole bean. Although because you'll most likely have beans of different sizes if Harrar, there could be some color variation due more to that and origin, greener, etc than due to our roasting method!You'll want to naturally sample some right then, but they will be far better after you let them air and degas for at least a day or two. Generally I do this in an open cardboard box or in the bag left open topped. My local market allows me to take some coffee bags from the fresh coffee bean section I use to store them in after that. When your spending $100's of dollars a month there, they can't complain. If they do, threaten to take your business elsewhere. I've never had to. From here you'll just grind 'em up to your liking and enjoy your first batch of Home Convection Oven Roasted Coffee! *_^ ......your grandma would have loved to have one of these new-fangled Convection Ovens. Don't you think?
Hello "JavaRock"
Wow! That was quite a first post!
Thanks for giving us such a detailed description of how you use your convection oven to roast coffee.
I'm curious to know......at what point do you usually set off your smoke detectors, and at what point does your wife complain that you're smoking up the house?
I know a lot of people who own counter top ovens that also have convection oven features, and they don't ever use the convection oven part. It's great that you've found a good use for yours.
Awesome post! It's a doable process at home using a wide variety of techniques. It can save you money, increase your enjoyment and appreciation of coffee, and the above is a killer guide to get you started.
Hello "JavaRock"
Actually Rose, I don't have a counter top convection oven. But I do have a built in combo convection/microwave oven w/ venting under it, above my Jenn Air Range/convection/oven. I use the convection oven in it and I only ever see a whisper of smoke make it's way out the range's vent and into the external fan/vent under the built in microwave. I've never used anything like Turbo Crazy or whatever. This Jenn Air Range is fantastic with excellent even circulation to the degree beans always end up very evenly roasted.
But I only roast to City/City Light or Full City in it. For French Roast or above, I use my barbecue drum on a spit out doors. This person/poster seemed to be concerned about money (or stove top) and my Jenn Air Range and stove top are what I started out with. I have never received a complaint from family ever and I usually plan on baking pizza after roasting a few batches of coffee indoors in our kitchen and everyone loves coffee hints/tastes. Although true I did smoke the house out trying to roast French Roast when I first started.
I also just wanted to say I try to write in a humorous way and not be looking down on people who've never home roasted coffee before. I also have a Bemor 1600 Roaster in my shop. Reality is that over the last 5 years my Jenn Air Range Convection Oven is my personal choice even over the Bemor. But my top choice is my barbecue drum roaster or an old 1920's roaster out in the shop. Anyway if I can help somebody learn a new way, when first getting into home roasting my posts will serve their purpose. You see... I was like this person with their questions on convection ovens 5 yrs ago. I couldn't get any answers in online forums, so I had to just experiment with using it and have had fabulous results. Got it down to a science now!
I've been using a convection oven for nearly a year. The coffee is great however the problem that i ran into that ultimately made me get a drum roaster was the chaff removal and the cooling. it took more time to dechaff and cool than it did to roast. It makes a terrible mess.
Well I do have a electric rotory turned drum in a barbeque for large batches and it's my main coffee roaster. But I am only touting using a convection oven for use if you have nothing else, don't have the money, you're just beginning home roasting or you just roast this way periotically like I do. Although for me the only inconvenience is in winter I take my fine wire screen with beans after roasting outside in the cold. Other than that it doesn't make any more mess than my barbeque. My Bemor is still a little more of a pain located in my shop but again chaff is chaff and it's sort of a pain to deal with no mater where or how you clean it. It's just someting I deal with.
Also I forgot to add that I preheat the foil or screen I use for roasting and only load the beans into the oven when the temp buzzer goes off and set the timer for 10 minutes. I prefer fine wirre screen and window screen also works great. With temps down around 10*F right now, beans are cooled in seconds tossing them between two pans then laying them out on a pizza screen and just rolling them around to remove the chaff out side that's left. I use a high speed blower for the large drum in the barbeque on the spit held in a rig set to the side of the barbeque. It too cools fairly quickly, but you just can't beat winter outdoors for cooling beans ultra fast in temps around 20*F outside!
I should also emphacise that I use a custom program on my Jenn Air Range convection oven to change and control temps, so that I've found the ideal patern for different roasts that I can't do with any other roasting method I use. The reality is that in roasting coffee you basically have two methods of applying heat to the beans in a consistent way. Either move/stir the beans in the heated air or move the heated air around the beans like in a convection oven. Naturally the less conduction (which is still being applied in a drum to a degree) contact heat the better. That's why I use a fine wire screen where the beans contact very little metal surface area and my roast are very consistent. With custom formulas my coffee beans come out exactly the way I want now. I've got the formula down to 5 to 10 seconds either way before pulling the beans. Removal from the oven takes less than 10 seconds and they're cooled in less than 20 seconds outside to stop the roast! ....it's a science for me now w/ just 3 ft to the outside from the oven! .....it may not be a professional level roaster, but the results definitely are great! :D
