wstsider
I have a serious question that I need to ask? Do I have to time my brewing when I do and second how much is enough water on the initial pour for the bloom because I think I’m not doing it correctly.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
it helps to time your pour over.
there are hundreds of youtube instructions, so it is rather easy to get the information.
after few practices, then, you can vary the time of your coffee taste liking.
again, it is all about "your own happiness and your own taste". because you will be the one drinking it.
so, vary the coffee volume, change the pour over time...etc.
good luck to you.
Timing is important. For V60 2;30 - 3;30 minutes. Mess with that range.
Bloom should be 2x the gram of coffee and you should let it bloom for 30-45 seconds
