Paintings made using coffee
CoffeeQuill
Hello all!
I am a coffee painter (aka starving artist) and have been making paintings (using strong coffee and ONLY coffee) of the fronts of coffee shops... but I can paint anything you like :)
Please let me know if you would be interested in having me make one for you! :)
13395154_1086058974787834_987779233_n.webpCoffee Painting of My Coffee Shop Coffee Shop.webpIspresso Coffee Shop Coffee Painting.webpSmithandChang Coffee Shop Front.webpVanilla Bean Cafe 1.webp
Coffee Painting for Dummiescould be a real book because it's that easy for anyone. The hardest part is just getting started - jumping in. The technique of painting with coffee is similar to watercolor painting but it's much easier to get started because the color range is limited to various stages of Brown. You don't get lost in as many choices and it's a good exercise in learning about the range of color values.
Safety Zone. Coffee is unexpectedly "forgiving" and can be erased after it dries on the paper. This is impossible with watercolor. However, once the coffee has been painted over pencil it can no longer be erased.
Blending. When a painted edge of wet coffee meets a section of clear painted water an automatic blend occurs This is similar to watercolor.
Is the entire sketch made with pencil first, and then it is colored in with the coffee paint?
i adore those! so cute!! you should try and get an art showing in a coffee shop if you haven't already, you'd probably sell a ton or at least it would be a lot of fun
Thanks Bagels!
