xyrik
Hi everyone,
I purchased a Krups XP4020 espresso machine together with a Krups burr grinder. After more than 10 different attempts at making espresso using complimentary Krups Arabica beans, I met with no success. Here are the few things that I noticed while brewing the espresso:
* When pre-heating the machine (ie. letting hot water pass through the filter sans grounds), a lot of steam is produced and it even leaks from the sides of the filter. Is it normal for the sides to leak water when carrying out the pre-heat? The filter unit is locked in tight for sure.
* When brewing the espresso with coffee ground using the 4th notch from the left, the coffee spurts out into the cup at very high pressure, spilling all over the place. This occurs about 2seconds after the brew was started. No crema's produced.
* When brewing the espresso with coffee ground using the 3rd notch from the left, the coffee grounds pass through the filter and the coffee again spurts out at high pressure. Again, no crema's produced.
Before each brew, I fill the filter to the brim with coffee grounds before tamping with approx 18kg of force. Also, there's no leakage from the sides when I brew with the grounds. I don't believe it's due to the grain size nor it is due to the tamping because I've tried so many times with different settings. May I know what else I can do to determine the cause of the problem? Thank you.
