Stevenmax
I have had my La Cimbali M32 Bistro for almost 10 years. I had to replace the pump in it a few months ago due to a leak. Since that time it seems to still loose alot of water in the tank from evaporation, I think. It might be steaming off, but I cannot see any steam coming from the release valve or anywhere else. Just a little while ago I started with a full tank. I made 1 drink. About 30 minutes later when I started to make another drink I saw where the pressure had dropped to zero. The tank is full. I turned the machine off, then on, and after a few minutes the pressure came back up. This is not an isolated incident. It has happened to me around 3-4 times now. On top of that, whenever I make a drink the pressure does not stay up like it used to. It drops out of the green. Normally it comes right back up. But I used to be able to steam milk and draw a shot at the same time. Now I have to do them 1 at a time. What can be causing my pressure problems?
