repstein
Greetings all,
I own a La Cimbali M32 Bistro (1 group). I purchased it used a few months ago. It appeared in great shape, but noticed the solenoid valve on the main group was allowing water to leak.
I contacted a somewhat local repair company (they are based in another part of the state, but have a local service tech). He replaced the Parker solenoid valve as well as a few other preventative maintenance issues.
A few days later, the valve wouldn't open. No water would come out.
He came by, replaced the valve again and everything was fine.
About 4 days later, the unit started leaking again. He came by, looked at the valve, and noticed it was starting to rust and the spring was a little damaged. For kicks, he replaced the valve again.
A day later (no joke), the valve is leaking again.
He tests my water and everything is normal. I have a GE Homespring whole house water filtration system as well as a salt-free water softener.
The water coming from the Cimbali however is nearing the upper limits of the test kit.
He suggests that there is scale buildup in the boiler and that the previous customer must not have had a filter. He states that his company can do it, but it'll cost over $800.
I have him replace the valve one more time, and sure enough, a week or so later, the same problem occurs.
Does this sound right? Has anyone ever experience anything like this? Any ideas?
Thanks in advance.
Regards,
Randy
Thanks in advance.
Regards,
Randy
