La Cimbali M24 DT3 convert to single-phase
Rego
Dear all,
I own a beautiful La Cimbali m24 with 3 groups and would like to take some advises on the process of converting it into single-phase power.
I have read the manual and although it looks pretty obvious I still have doubts related to the wiring setup.
Here is the manual:
w w w. hermelinhandels.se/search/download/file/p1795aftro1i37rb41cil102nuol6.pdf
I live in Germany (220v) and want to setup the machine for single phase. The power cable is composed of 5 colored internal wires: White, brown, black, blue and yellow(earth). The machine specifies the electrical connectors as T,S,R,N
Questions:
1. Page 23:building the cable connector fig 4 does it mean the white-blue go together (N) and the brown-black as well (T)? How should I setup the wiring on the plug?
2. Page 27: should I join as well here the white/blue (N) and the black/brown(T) and then connect the bridges with an independent wire?
3. which power concerns should I have for a home single phase power installation?
Thank you in advance for you help.
Best regards
Hugo
