Hi,
I'm an espresso newbie and recently bought Gaggia Espresso Dose with Maestro grinder. (it's semi-automatic with 58mm pf, non-pressurized)
I've been experimenting with this machine and got so frustrated because I can never get a good shot.
First off, I've tried various settings on Maestro, and from 0-40 with 0 being finest and 40 being coarser, I tried from 0-14 like the instruction manual said for espresso grind but it still seems too fine for my Gaggia. At 0-5 fine grind, the machine would not drain the espresso but instead it will overflow through the sides of pf, causing a pop when I take out the pf. I tamped very lightly, probably around 5lb force. Using 6-10 grind setting, I get the espresso but absolutely no crema, same with 11-14 setting. The pulling time normally takes 15-20 seconds for single shot but I get really dark and bitter espresso with no crema. Obviously I'm doing somtehing wrong here but cannot figure out what.
Also I've read on the internet that I need to fill the pf with coffee to creat mountain and scrape off the top to start with and tamp, but when I do this the coffee level would be too high even after tamping and the pf won't lock into machine, creating a huge mess to the shower head.
Very frustrating. Could somebody help? What am I doing wrong?
