Help with Saeco espresso machine.
Swcejk2002
Maine
Hello and good day all. I have a Saeco espresso machine hd8856. Once i turn it on anf fill tank water starts leaking from this one area. Its coming directly from the tank. I attached a couple of pics. I pointed to where i think water is coming from (i used compressed air to blow up from other pic). I suppose the other part of tank could be where its coming from too. Hoping for some suggestions. Thanks
Try to remove those 3 visible small screws and you will get behind that plastic mask.
you will see another 4 screws holding that plastic inlet. It has. To show where water is leaking from. Burst hose or that plastic valve on picture.
Rubber rings if needed you may buy on Amazon.
This is as far as you can go and see from where you are.
Other than this, you may go to an authorized service near you.
Cheers
