Help Please: WMF 1000 pro air pump repair
_kopi_luwak
10
Good afternoon. Help me with some advice. I disassembled the milk air pump of the WMF 1000 coffee machine. I was distracted and didn't take a photo. What position should the grey gasket on the piston be in? face down or face up? see the pictures.
  • #3
Do you still need help? I can take a look at my spare if you want...
Thank you very much. I found the answer on the manufacturer's website. The answer is as I expected. The correct option is to install the plate with the upper faces up. The correct installation is shown in the picture.
Did your repair workout? Every Pump i opened was at the end more broken then before :-( Atm im doing experiments with chinese pumps.. Some work pretty good for 5 Euro ;-)
  • #6
Yes, the pump works. In our country, a used pump costs $50 in coffee machine repair shops. where can I order such pumps in China? I saw some on aliexpress
Mostly with the used i and other people dont had much luck :)
Yes their from Aliexpress but im still figuring out, which ones work good and bring enough pressure against the steam. Also a question is the lifetime and the mounting. But i will keep you posted, when i found a good model.
Alex
  • #8
Alex
There is an air flow restrictor in the pump in my coffee machine, I think in my case it will be a problem to choose another pump.
