Help Please: Troubleshooting Espresso Machine
SpicyRiceTea
14
My friend gave me his ostensibly broken espresso machine, with the promise that if I fixed it, I could keep it.
It seemed to be that the pump wasn't working, even though when I turned it on it did make quite a bit of sound.
Then I bumped into this video that showed a way to unseize the pump, I then tried this myself: https://www.youtube.com/watch?v=HafRStI3rNg
The results were as follows:
1-The water did not drain from the group head
2-The water did not seem to be flowing unless I manually inserted it with a syringe
3-Once I'd inject the water manually, the spigot would be able to work
One more thing worth mentioning is that I had previously unfastened the connection between the boiler and the pump, and when I turned on the pump, water still didn't flow.
So with this information, would it be a fair assessment to conclude that the pump is the issue?
Should my next step be to buy a new one?
Cheers
