brewitup
Hi all,
Any Jura experts out there. I just finished rebuilding the brew group and reassembling the machine.
I noticed something odd. The drain valve male port does not seem to be connected to anything, but has an o-ring.
Is this normal? The only hoses I recall disconnecting to remove the brew group is the the drain valve female port (clear hose held in with a clip).
You can see it on the machine if you pull the grounds tray, and look inside. Its right below the plunger.
thanks
thanks
