PMartin
Hi,
I have a problem with my francis Francis X1 (first generation aluminium boiler) it only heats to 80°. I opened it and tried some setting with adjusting the resistor (1K ohm) but nothing really changes.
I also tried other settings with the 10K ohm resistor (this ones is normally glued as fixt setting). But I don't get the temperature above 80°...
I measured the water temperature with a thermometer directly at the nozle when it comes out.
If I pull out the thermometer out of the boiler the water temperature easily goes up and over the 100°.
Anybody with similar problems and a fix?
Kind regards,
Martin
Kind regards,
Martin
