I have a Jura Impressa E8 machine. The machine stopped during a cleaning. The coffee scrapper was in part way down when it stopped. I took apart the machine, cleaned it and put it back together again. Now it sounds like the grinder is stuck at the top of the machine and makes a loud ratcheting noise. I’m wondering if it isn’t the brew unit or the encoder that went bad.
Any thoughts?
I don’t want to purchase a part that is not causing the problem and the cost to send them in is very expensive. I’ve had the machine for 15 plus years and have always cleaned and took care of it. There was no excess coffee grounds or discolored coffee anywhere in the machine when I cleaned it. Any ideas are appreciated.
I hope I am able to repair the machine myself. I would also like to hear what others would recommend that I replace it with if I am unable to get it repaired. I would prefer a machine that works similar to the Jura, fill beans and add water, little cleanup.
Thanks, Tom
Any thoughts?
Thanks, Tom
