Law104
Good Day
I am roasting on a Diedrich IR5 2016 model, using propane gas.
I am trying to not let my ET fall below the BT post FC.
Note;
1) At charge my ET is always lower than my BT. (not sure if this indicates a probe issue)
2) I only use 50% fan at approx 140 C. According to Scott Rao my fan sucks way to much air through the trier, when using the lighter test.
3) About 1min after FC my ET and BT cross over. I.E my ET is now lower than the BT.
4) Generally my ROR's are declining without noticeable "flicks or crashes"
5) My TP's seem a bit low 75 C.
My question is how could I avoid my ET dropping below my BT, without adding pressure after FC.
Please request any information that you think necessary to help.
Thank you..................
Note;
