DCR
I purchased an old (circa 1994) Diedrich IR-12 and just got it hooked up to natural gas. Upon firing it up, the Drum and Blower motors turned on and the pilot light light up no problem, nice big blue flame. The burners will not ignite. I did some trouble shooting and confirmed that the Ignition module is working (I'm getting 25V at PV to MV/PV terminals), the gas line from the valve to the pilot light is working since the pilot is fully lit, I even turned the set screw on the vacuum sensor unit to see that it will shut off the pilot light. So, are the burners not getting gas because the valve is not opening, and if so why is it not opening? or is the gas pressure too low? I was told it is at 7 W.C. at the street/meter. If anyone has any info, I would be forever grateful. Thanks, Paul
