Hi everyone,
So I have been researching what it takes to put together a suitable coffee lab; how one can cup roasts and samples with consistent results.
I came across this article: http://www.sustainableharvest.com/wp-content/uploads/2013/01/Roast_MayJun11_LabReport.pdf?55e073
In a nutshell, it expresses that everything needs to be clean, well maintained, well lit, free of smells and consistent (goes on and on into more sophisticated practices). Then gives a bare bones list of the following items that are essential to a Lab:
Any thoughts on that list?
Also, I was expecting there to be mention of an espresso machine somewhere in the article, but no mention. Wouldn't that be a critical piece of test equipment? I understand that you can profile the espresso roast using cupping, but I feel like it should be there to test/showcase on.
If so, what are opinions on the quality? You can go bonkers spending thousands on an espresso machine. Any suggestions on which type is good for a roaster's lab?
Thanks in advance
- Dedicated burr grinder
- Cups
- Spoons
- Digital scale
- Timer
- Hot water source (kettles/tower,etc)
- Thermometer
- Sample roaster (if your roaster is too larger to produce batch size results)
Thanks in advance
