Digestion problems !
darek_k
hi everyone,
I take 7-8 cups of coffee in a day , from last 5-6 days digestion system become so weak, cann't explain .is it cause of too much coffee? now i just taking 2-3 cups of coffee a day .please advise me.
thankx
Caffeine effects different people in different ways. If you are not used to drinking 7-8 cups a day...maybe this is the cause. Then again...why would you sudenly start drinking so much coffee, if you were not before? I am hoping you are not part of that mushroom group? :grin:
Shrooooooms, pretty, want to touch the shrooooom.......Coffeeeee, too hell with the shrooms! :wink:
The only way to eat mushrooms is lightly fried in olive oil, with some crushed garlic and served on rye toast. Ground up in a dodgy beverage??? blah!
I like them raw, pretty good on a salad, but I am a sucker when they are stuffed with filling and smothered in butter. :P
..... and sprinkled with ginger :grin: :grin:
Alun_Evans - nice recipe !! I wonder if I could eat that for breakfast ! You've made my mouth water. :D
Mushroom water, not so much..... :wink:
you'd better cut on the number of cups. coffee can cause hyperacidity so better make sure you take something with your coffee or better yet, eat first before your first cup. :wink:
Too much caffeine can certainly make you feel weak. Cut back.
well
might be easier to answer this if you could define..."become so weak". Sounds like the coffee is effecting more than your stomache
Seen too many shrooms in my day to stomache them...liguified, fried, stuffed or grown in a lab dish. Good way to ruin a pizza.
Indigestion maybe a result of too much caffeine. To solve your digestion problem, you can use an herbal supplement that is very effective. We call this supplement as Mimonis Digestic, which is purely organic.
are you a Minonis Diegestic user? or seller?
By the way, welcome to our forum. I can see this was your very first posting.
hi everyone,
thankx
Medically proven that too much coffee can be the cause of digestion problem. there are two things in Coffee that cause it. Caffeine & Acidity of coffee.
So, i guess... if you drink De-caffeinated cold-brewed coffee, that will solve the problem.
Drinking too much coofee can be harmfull to health but drinking regularly can make you healthy as well:coffeecup:..Drinking the coffee with some other food an be cause for your all this shit..as you dercrease the daily number of coffee cups then i hopw it will be better in some time !:coffeespill:
if you drink too much caffeine is quite likely you will have several digetive complications that I myself did experience like:
heartburn: caffeine makes your stomach sphincter relax, as well as it will stimulate your stomach to produce way more acid than it was supposed to, and then it comes up your throat burning everything on its way.
gastritis: if you drink a lot with your belly empty, there you go, lots of acid floating around with nothing to chew on
and finally....
DIARRHEA
if you got to the point to be s******* in your pants you should retreat mr., too much caffeine is laxative. Each body has its own tolerance rate, don't overboard. Is really paramount that you also eat more as you increase the consumption of coffee because, besides increasing the amount of acid in your stomach and working as a laxative, it also boosts your metabolism, perfect recipe to diarrhea. Take care and don't dehydrate.
