ilovesweetmarias
Hello All Coffeeforums members,
I’m new here but was hoping that someone would please help me. I’ve had my Bunn A10 Commercial machine since new. Coffee always tasted top notch! I realized as of late the coffee brewed was flat tasting and really not doing a great job of waking me up either. So I started poking around doing some research. I measured the temperature in the inlet hole of the tank. It read 185.4. So, I figured that I’d replace the thermostat. The 2 in-line thermal fuses too because insulation looked burnt dark brown and the new in-line thermal fuse insulations was clear. Once the new thermostat & thermal fuses were installed the temperature read 197.8 F. The coffee tasted better than it was but I swear it’s not as good tasting as it was when the unit was new? I only use filtered water and I grind beans fresh with a Baratza Encore at like setting 18. I really enjoyed this machine but I don’t want to keep throwing expensive parts at it. When I could just but a new commercial Bunn or maybe try a Technivorm. I would be very gracious if somebody would lend me some of their expertise! Thank you very much.
Robert
Robert
