BEZZERA MAGICA PORTAFILTER LEAK
assaf.aman
Hi
Every time I make coffee I get a small leak from the brewing head.
I always make sure that the portafilter is not over filled, that the coffee is evenly spread and bellow the mark.
I also clean the brew head every few months. The machine is about two years. Could be that its time to replace the o-ring?
Personally would clean the group more often... my routine is a water backflush and wiping the screen/group gasket thoroughly after each daily session and a detergent backflush/parts soak every 2 weeks. Varies depending on machine design/use obviously.
Based on what you describe replacing the gasket might be a solid fix. I'd recommend using a silicone replacement like those from Cafelat. They seal far better/smoother than OEM rubber and really don't wear out or harden in time like rubber.
