odoman357
I've used this Nut roster only a couple of times because my schedule is very busy. I was advised to cut back on coffee due to health reasons, but when I did use it, it worked perfectly. The only thing I had trouble with was the timer, so I ended up manually timing each batch, which turned out just fine.
I'm selling it for $1200 non-negotiable, because it is still as new and I'm also including the remaining items from my inventory, such as portion cones (750 counts), Frosted Nut Mix (9), and gallon jugs of Vanilla (2).
Send me a direct message or email [email protected]
These items have been stored in a clean, dry facility, and there's no expiration date that I can see. It's up to you whether you'd like to use them.
