AndyP
- Jun 9, 2014
- 59
- 0
Advice needed from experienced roasters. I'm roasting on an Ambex YM5. I was mid-roast on my first batch after the roaster had warmed up to 430 for 45 min, and the warehouse I'm in had a power outage. Quickly found out it was due to roadside utility work. I had no idea what to do, so I unscrewed the rear casing of the machine and hand rotated the drum a few rotations per minute in an attempt to keep the hot parts moving and get the beans out. It started to cool down (from 330 to 200) and after 30 min the power came back on. Is there anything that can be done if this happens again? The manual states that the machine must never be shut down until it cools below 150 deg. to avoid warping the drum and damaging bearings. (I'm the paranoid roaster who waits until 140 just to be safe). It seems totally fine of course. Any experience with power failures on Ambex machines or any other "emergency" situations or tips you can share would be appreciated!
Thanks!
Thanks!
